access-list issue
We know access-list 12 permit 192.89.55.0 255.255.255.0
is invalid, because the wildcard is wrong.
My problem is that the router did not give you any error message when type it in the router, instead it changed to access-list 12 permit 0.0.0.255 255.255.255.0 and added in the router. this cause a lot of problem because some of the network address is passed the filter.
Is it the bug in Cisco IOS?
R7>sh ver
IOS (tm) C2600 Software (C2600-JK9O3S-M), Version 12.3(12), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 29-Nov-04 15:39 by kellythw
Image text-base: 0x80008098, data-base: 0x81FB49F0
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-JK9O3S-M), Version 12.3(12), RELEASE SOFTWARE (fc3)
R7 uptime is 3 days, 19 hours, 46 minutes
System returned to ROM by reload
System image file is "flash:c2600-jk9o3s-mz.123-12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco 2621XM (MPC860P) processor (revision 0x100) with 94208K/4096K bytes of memory.
Processor board ID JAE07330L5V (761626841)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
R7>
sundar.palaniappan Mon, 02/26/2007 - 14:46
It's not a bug in the IOS. 0.0.0.255 255.255.255.0 is a valid access list statement in which the router doesn't care about the first 3 octets. Any traffic from .255 is the only traffic that will be permitted. Though, in your case, it's a broadcast address and cannot be used. There can be many situations where someone entering a subnet mask by mistake in an ACL could translate to a valid/useful access control entry. Hence, the router always translates the ACE to the right address/wild card mask.
It's easy to make a typo or an unintentional error when configuring access list. After configuring an ACL, I always double check my work by doing a 'show access-list (#)' and verify that it's configured the way I want it to be.
Sundar
deilert Mon, 02/26/2007 - 16:27
Kevin the router is interpreting the wildcard mask just as it was put in
192.89.55.0 255.255.255.0 = ingnore first octet, ingnore second octet, ingnore third octet and match the last octet of the ip address, hence the 0.0.0.255
