802.1x monitoring
Feb 26th, 2007
I am using IAS to authenticate the machines on my network. What is the best way to monitor any failed authentication attempts at the switches?
acomiskey Mon, 02/26/2007 - 18:20
You can alway check the "System" logs in the event viewer of your IAS machine.
jms112080 Tue, 02/27/2007 - 05:59
We use the IAS logs, but when using machine certs as we do for authentication, if a "rogue" machine with no cert plugs in and fails, I have no way to know it ever happened. There is no log entry in IAS when a machine doesn't send some kind of authentication attempt.
acomiskey Tue, 02/27/2007 - 06:17
What about snmp traps?
Try IEEE8021-PAE-MIB or CISCO-PAE-MIB.
