Redistribution problem
Feb 26th, 2007
Hi, I've got a classic core-distribution, with a FW in access layer.
EIGRP between core-distribution and OSPF between FW/access-distribution.
configs as follows:
core:
router eigrp 1
network 172.16.0.0
no auto-summary
interface fa0/1
ip address 172.16.1.1 255.255.255.254
distribution:
router eigrp 1
network 172.16.1.0 0.0.0.1
network 172.16.165.0 0.0.0.3
no auto-summary
eigrp stub connected static
router ospf 1
area 1 stub
network 172.16.165.1 0.0.0.0 area 1
network 172.16.22.1 0.0.0.0 area 0 (just a loopback interface)
int fast0/1
ip address 172.16.1.2 255.255.255.254
int fast0/2
ip address 172.16.165.2 255.255.255.254
The OPSF network exists on the distribution switch, but it will not redistribute it into the core, can anyone explain what I'm doing wrong?
deilert Mon, 02/26/2007 - 16:39
i do not see where there is any redistribution configured. Do you want the 172.16.22.1 in EIGRP ? If so add a network statement in EIGRP 172.16.22.1 0.0.0.0
770801tvdhaar Tue, 02/27/2007 - 00:19
Sorry forgot the redistribute part!!!!
I want to redistribute OSPF into EIGRP.
distribution:
router eigrp 1
no auto-summary
redistribute ospf 1 metric 100000 100 255 1 1500
router ospf 1
area 1 stub
int fast0/1
int fast0/2
deilert Tue, 02/27/2007 - 03:57
The subnet mask of ip addresses you have on the Fe's should be 255.255.255.252 not 254
can you change them and change the network statement in OSPF to 172.16.165.0 0.0.0.3 area 1 then paste in a sh ip eigrp top 172.16.165.0 255.255.255.252
Richard Burts Tue, 02/27/2007 - 04:29
Tyrone
There are several parts of this config that may be problems. Here it is for reference:
router eigrp 1
no auto-summary
router ospf 1
area 1 stub
int fast0/1
int fast0/2
- As noted before the mask of 254 on both fastethernet interfaces is problematic.
- the network statement in eigrp network 172.16.1.0 0.0.0.1 would seem to intend to match fastethernet0/1, but the mask used of 0.0.0.1 will match only 0 and 1 in the last octet and the interface is .2. The fact that it is not included in eigrp can be confirmed by show ip eigrp interface. This means that there is no eigrp running between distribution and core.
- it appears that the intent is to have interface fastethernet0/2 in both eigrp and ospf. I wonder why it is intended to be in both. And in fact the network statement mask used in ospf does not quite match that interface:network 172.16.165.1 0.0.0.0 area 1
- and perhaps the most important issue is one that we do not have enough information to answer yet. What ospf routes are known on the distribution that would be redistributed. The output of show ip route ospf on distribution would show what routes have been learned by ospf and could be redistributed to eigrp. Without knowing that we can not know whether redistribution is working or not. The syntax of the redistribute command looks ok, but the question is: are there ospf routes to redistribute. (Given that the only ospf network statement that seems to match is to a loopback, I am doubtful that there are ospf routes to redistribute.)
Rick
