Basic Question for configuring 7914 with CME
Answered Question
Feb 26th, 2007
Ok - I've searched google for a few hours before posting this and hadn't found the information I needed, so I figured I'd ask the gurus over here.
Basically, I have a small office with 8 phones and 2 have the 7914 expansion card on them, and I'm using Call Manager Express on a 2821.
All I want to do is configure the darn things, and all I wanted was a step by step to do this, this and that and done.
Is there a configuration guide out there that I'm not finding or is this top secret info?
and just to make sure, would it matter if the phone was turned on while I'm configuring them (the cards) or not?
Al
Correct Answer by rtappend_2 about 9 years 7 months ago
CCME v4.0 Administration Guide
Phone Provisioning
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00806a8022.html#wp1004067
The expansion card is attached to the phone, so you have to configure them both together, or rather the expansion module configuration is part of the phone configuration.
Overall Rating: 4 (2 ratings)
gogasca Mon, 02/26/2007 - 15:14
Hi Al,
Heres a sample config for my lab CME}.
tftp-server flash:S00105000200.sbn
telephony-service
load 7960-7940 P00308000400
load 7914 S00105000200
max-ephones 16
max-dn 32
ip source-address X.Y.Z.W port 2000
timeouts interdigit 7
timeouts ringing 15
system message APAC CCME
create cnf-files version-stamp 7960 Feb 22 2007 05:07:28
voicemail 33999
max-conferences 4
dn-webedit
transfer-pattern 3....
secondary-dialtone 9
ephone 1
mac-address 000D.BC04.9885
type 7960 addon 1 7914
button 1:1 7:30 8:31 9:32
ephone-dn 1 dual-line
number 33001
label 33001
name APAC 1
call-forward busy 33999
call-forward noan 33999 timeout 12
ephone-dn 30 dual-line
number 33030
ephone-dn 31 dual-line
number 33031
ephone-dn 32 dual-line
number 33032
Paolo Bevilacqua Mon, 02/26/2007 - 15:50
Configuration guide, command reference, network design reference manual, ad-hoc TAC guides and this forum itself. CME (and in general, IOS gear) use and fine configuration is far from secret. Just type freely in the search form on CCO and you will be overwhelmed by the information available.
amiralisetoudeh Mon, 02/26/2007 - 19:05
Hey guys thanks for your replies... I appreciate the sample config - It's just that I'll need a step by step for configuring it, and I don't know why it's not 'easily' available. (believe me, I searched google and cisco for hours)
And to the second reply, I said I've already searched most of what I've known to be resourceful - no luck.
I probably should restate that I'm looking to configure the 7914 expansion card, not the phone itself - plus, I'm using Call Manager Express.
It should be really simple... and all I need is a little pdf from Cisco that explains it... nothing tough.
Al
