Missing log from fwsm
Feb 26th, 2007
I noticed that some of our fwsm traffic log is not appearing in the syslog server. I noticed in the show logging queue, it's reporting discard messages like below:
fwsm# sh logg que
Logging Queue length limit : 512 msg(s), 921036 msg(s) discarded.
Current 512 msg on queue, 512 msgs most on queue
fwsm# sh logg que
Logging Queue length limit : 512 msg(s), 921654 msg(s) discarded.
Does anyone know what it mean by this ? I have tried to increase the queue to 2048 but after a few minutes, it start to fill up and discard message counter increase. I tried to set unlimited but the Current Msg counter keep increment without going down. Does this mean the fw is dropping or the syslog server is too slow to serve ?
Any comments or ideas are welcome
Justin Vo
Overall Rating: 3 (1 ratings)
Disable local logging ...
Only test with logging trap 4 and then with trap 7.
Check your logging server and check trough a repeated ping if the connection is not dropping.
If you find this post usefull
please don't forget to rate this
#Iwan Hoogendoorn
justinvo Wed, 02/28/2007 - 02:38
I have done some tests and what i found is the logging console 7 seem to be the cause. I turned it off and the queue reduced down to 0.
