DSDomino error 1014
Feb 26th, 2007
Can anyone shed any light why Unity is not recovering on it's own when it loses connection to a Notes/Domino server? This is a Unity 4.0(4) SR1 setup. This seems to happen on the weekends the past 3-4 weeks with same symptons. Nothing has been found going on with the notes servers or network at time this has happended.
After this error happens, the following has happened:
-- VMs get put in UnityMTA folder and keep piling up there until unity is restarted (they don't go to the failed folder).
-- Unity does not answer calls at all, but all services are up/started and system tray shows good.
Event Type: Error
Event Source: CiscoUnity_DSDomino
Event Category: Error
Event ID: 1014
Date: 2/24/2007
Time: 7:54:30 AM
User: N/A
Computer: UNITY1
Description:
Cisco Unity couldn't open the Notes database names.nsf on Server NOTES/AB/AandBCompany. Notes system error ?J???.
Also, does anyone know how to get rid of the errors every 30 mins about unity not able to connect to Notes server where DUCS is not installed that the unity server does not have any users on?
jacoffeyajc Mon, 03/05/2007 - 10:09
I'm running 4.0(5) and ran in to a similar issue. We installed Engineering Special 74 and it went away. If the ES applies, I beleive you'll need to open a TAC case for access.
jshelmer Mon, 03/05/2007 - 12:17
Can you share the BugID or Caveat that ES74 fixes? Thanks.
