AvDoh error with Notes - Unity 4.0(4)
Feb 26th, 2007
Any one have any ideas on what is causing Doh errors with Unity and Notes?
Event Type: Error
Event Source: CiscoUnity_AvCs
Event Category: None
Event ID: 100
Date: 2/26/2007
Time: 10:06:49 AM
User: N/A
Computer: UNITY1
Description:
Exception occurred and handled. File: e:\views\cs_ue4.0.3.159\un_Doh1\Doh\Src\AvDohContainerImpl.h at Line: 364 - Error: 80004005H Call stack:
0x5E80414D AvDohSvr.dll: <unknown symbol>
From the AvCs Log file:
10:05:14:630,AvDiagnostics_MC,1440,4088,1,111EDC12A7414B28BC43D27B86E86C9C,MALLn,10,Count found 13 documents
10:05:17:068,AvDiagnostics_MC,1440,4088,1,111EDC12A7414B28BC43D27B86E86C9C,MALLn,10,Filter Value: AVP_SEARCH_FOLDER_TYPE = AV_SEARCH_FOLDER_NewNonUrgentVoiceFilter
10:05:17:145,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo(ReturnReceipt) ((0x222) Note item not found)
10:05:17:146,**,-1,1308,-1,,NotesCommon,13,Unable to convert time to local
10:05:17:145,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo(AVP_SENDER_ADDRESS_TYPE) ((0x222) Note item not found)
10:05:17:146,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo(AVP_CALLER_ANI) ((0x222) Note item not found)
10:05:17:192,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo($KeepPrivate) ((0x222) Note item not found)
10:05:17:286,AvDiagnostics_MC,1440,4088,1,111EDC12A7414B28BC43D27B86E86C9C,MALLn,10,Opening File: C:\DOCUME~1\unitysvc\LOCALS~1\Temp\AV_CA5.wav
10:05:17:287,**,-1,1308,-1,,NotesCommon,14,PropID 0x7212000B not supported
10:05:40:395,AvDiagnostics_MC,452,4088,1,111EDC12A7414B28BC43D27B86E86C9C,CDE,14,GetPropBool,GTMEnabled,0x00000000,66,H:\views\ESB1_view\un_Conv1\AvConvSubscriber\AvConvSubMsgPlaySvr\AvSNotifyMsgMoved.cpp
10:05:41:271,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo(AVP_SENDER_ADDRESS_TYPE) ((0x222) Note item not found)
10:05:41:270,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo($KeepPrivate) ((0x222) Note item not found)
10:05:41:864,AvDiagnostics_MC,1440,4088,1,111EDC12A7414B28BC43D27B86E86C9C,MALLn,10,Opening File: C:\DOCUME~1\unitysvc\LOCALS~1\Temp\AV_CA6.wav
10:05:41:865,**,-1,1308,-1,,NotesCommon,14,PropID 0x7212000B not supported
10:06:14:113,AvDiagnostics_MC,1464,4132,2,EBBE9B0E4849447DBE905145E1B6F1E2,MALLn,10,CAvMALLnMessage,CAvMALLnMessage::SetEx,H:\views\ESB1_view\un_Doh1\MalNapi\MALLn\AvMALLnMessage.cpp,2575,00001024H,03221660H
10:06:28:926,AvDiagnostics_MC,452,4088,1,111EDC12A7414B28BC43D27B86E86C9C,CDE,14,GetPropBool,GTMEnabled,0x00000000,66,H:\views\ESB1_view\un_Conv1\AvConvSubscriber\AvConvSubMsgPlaySvr\AvSNotifyMsgMoved.cpp
10:06:29:629,AvDiagnostics_MC,1440,4088,1,111EDC12A7414B28BC43D27B86E86C9C,MALLn,10,Filter Value: AVP_SEARCH_FOLDER_TYPE = AV_SEARCH_FOLDER_NewReceiptFilter
10:06:29:707,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo(ReturnReceipt) ((0x222) Note item not found)
10:06:29:707,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo(AVP_SENDER_ADDRESS_TYPE) ((0x222) Note item not found)
10:06:29:708,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo(AVP_CALLER_ANI) ((0x222) Note item not found)
10:06:29:723,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo(Importance) ((0x222) Note item not found)
10:06:29:724,**,-1,1308,-1,,NotesCommon,13,NSFItemInfo($KeepPrivate) ((0x222) Note item not found)
10:06:40:816,**,-1,4228,-1,,NotesCommon,13,NSFItemInfo(From) ((0x222) Note item not found)
10:06:41:082,AvDiagnostics_MC,1142,4128,1,75533EE1A77E4771A3593724297DEF25,-1,-1
10:06:49:723,**,-1,4088,1,111EDC12A7414B28BC43D27B86E86C9C,NotesCommon,14,Timeout waiting for proxy stub execution on thread ID=1308
10:06:49:832,**,-1,4088,1,111EDC12A7414B28BC43D27B86E86C9C,-1,-1,Exception caught e:\views\cs_ue4.0.3.159\un_Doh1\Doh\Src\AvDohContainerImpl.h 364 80004005H
10:06:49:973,CiscoUnity_ConvSubscriber,119,4088,1,111EDC12A7414B28BC43D27B86E86C9C,-1,-1,IAvDohAttachments::Count,0x80004005,255,H:\views\ESB1_view\un_Conv1\AvConvSubscriber\AvConvSubMsgPlaySvr\AvSPlayMsgRoot.cpp
Zin.Karzazi Tue, 02/27/2007 - 04:17
If the Unity version is 4.0(4) and the message description below appears, apply Unity version 4.0(4) Service Release 1 (SR1) immediately to avoid service interruption:
Exception occurred and handled. File: e:\views\cs_ue4.0.3.159\un_Doh1\MalMapi\MALEx\AvMALExSession.cpp at Line: 1124 - Error: 80004005H Call stack:
0x5E16A05D AvMalExSvr.dll:
You can see this error when trying to access the SA and an error message stating 'Access denied - You cannot access the Unity System Administration. - There are too many active sessions. - Please try again later. - Please see your system administrator for more details.' is displayed and the following error message is logged to the application log:
Exception occurred and handled. Contact Cisco Technical Support. File: e:\views\cs_ue4.0.0.280\un_SA1\SA\avsadbconn\AvSaDbSession.cpp at Line: 7581 - Error: 80004005H Call stack:
0x5DC2006D AvSaDbConn.dll:
This will occur is the AvDSAD service has not started prior to accessing the SA. To resolve this issue ensure that the AvDSAD service is running.
Another cause of this error can be related to a bug in handling apostrophes in subscriber alias strings. This issue is detailed in DDTS under record CSCeb13891: http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCeb13891&Submit=Search
Always go to:
http://www.ciscounitysupport.com/find.php
to see what the Errors means.
Hope this helps.
Erick Bergquist Tue, 02/27/2007 - 07:24
Yea, we are on Unity 4.0(4) SR1 and that is the notes from the unitysupport.com site which don't match up to this error.
rpsunbeam Tue, 02/27/2007 - 12:02
I had exactly the same error last week with 4.0.5, I re-ran the setup with "-sync" parameter and everything was fine after that.
fossilev700 Wed, 05/02/2007 - 09:45
I recieved this error today but am running Unity 4.2(1) port 4 was stuck bust for 885:45
Event Type: Error
Event ID: 100
Date: 5/1/2007
Time: 5:12:26 PM
User: N/A
Computer: UWUNITY
Description:
Exception occurred and handled. File: E:\Views\CU4.2.0.110\un_Core1\Arbiter\AvArbiterSvr\AvArbiterWorkerThread.cpp at Line: 209 - Error: 80004005H Call stack:
0x5FEAFAAD AvArbiterSvr.dll:
