Configuring Vlan
Feb 26th, 2007
I have created few Vlans in my switch (Layer 3). when i give show ip interface brief, some vlans are showing NVRAM (under Method) and some are showing as Manual. Can anyone tell me what is the difference between them. I hv attached the command output also.
Kiran
Rolf Fischer Tue, 02/27/2007 - 01:56
I gave it a try with a Catalyst 2950.
There are 2 ways to create a VLAN:
- in configuration-mode: (config) vlan x
- in vlan-database-mode: (vlan) vlan x name y
The conifg-file is stored in NVRAM and the VLANs created in the config-file are show as 'NVRAM'.
When creating new VLANs they are first shown as 'manual' - after rebooting the switch they are shown as 'NVRAM'.
