DMVPN ISSUE
Answered Question
Feb 27th, 2007
I have deploy a dmvpn topology with two hub's and several spokes, after the spokes and the hub's working i made a reboot in the hub to see if everithing work afther the rebbot of the hub, but i notice that after the rebbot the tunnel in the hub did not came up, the only way to bring the tunnel up was to clear dmvpn session static in the spoke, during this the hub keep giving a message:
ISAKMP: ignoring request to send delete notify (no ISAKMP sa) src 213.10.10.10 dst 213.58.10.10.14 for SPI 0xC15C587F
IOS:12.4.11T1
2821
2811
Can any one help me.
Correct Answer by Kamal Malhotra about 9 years 7 months ago
Please make sure that you have ISAKMP keepalives configured on the hubs and the spokes and once configured, please test again and see if it improves. Probably what is happeneing is, when the hub rebooted, the spoke did not clear the tunnel rather is depending on the SAs to timeout. When we clear the SAs on the spoke, the problem goes away. Configuring the ISAKMP keepalives should get us around this problem.
HTH,
Please rate if it helps.
Kamal
Overall Rating: 5 (1 ratings)
Correct Answer
Kamal Malhotra Tue, 02/27/2007 - 09:24
HTH,
Kamal
patcbr600 Wed, 02/28/2007 - 01:19
I ,
I have try to configure the keepalive and after this with the reboot of the everithing was ok.
Thanks for your help
