Reconfigure transcoder to gateway
Feb 27th, 2007
We have a Cat 6000 switch on which there is a WS-X6608-E1 8-port gateway.
3 ports are being used as gateways.
5 ports are being used as transcoders/media termination points.
My query is whether we can temporarily take one transcoder port and convert it to a gateway.
Is it possible to do this?
How can we find out what the impact will be on the remaining transcoders?
How can we reconfigure this?
Overall Rating: 4.5 (2 ratings)
rob.huffman Tue, 02/27/2007 - 10:22
Hi Moiz,
This is very possible. You could take out/change 1 of the MTP/Transcoding ports to a Gateway port and change it back if required. Here are 3 good 6608 docs that should help;
How to Use Cisco CallManager to Configure a Catalyst WS-X6608-T1 Port as a T1 VoIP Gateway
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00801152b9.shtml
WS-X6608-T1/E1 Digital Gateway Card on the Catalyst 6000 Platform Problem Resolution
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a008045a3c0.shtml
Configuring a Catalyst WS-X6608 Port as DSP Resource for Transcoding and MTP Using Cisco CallManager 3.3(x) and 4.x
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00801f9784.shtml
Hope this helps!
Rob
dgahm Tue, 02/27/2007 - 12:28
To add to Rob's excellent post, you can tell how busy your transcoders are with show port voice active X/X. Do this a few times during your busiest call hour for all your transcoders and you will get a good idea of the impact of removing one.
RTMT would also provide this information. Open Performance Monitoring and select Cisco Trancode Devices > Resource Active for each of your transcoders.
Dave
