Interfaces on standby Supervisor Engine IV
Answered Question
Feb 27th, 2007
On a Cisco 4507 with Redundant Supervisor Engine IV. Can the Interfaces/GBIC on the standby Supervisor be used or can you only use interfaces on the current active supervisor. I cant find any documentation on this.
Kev
Correct Answer by hoogen_82 about 9 years 7 months ago
The first module on both Supervisor engine would be active. The second module on both Supervisor engines will not be accesible.
This document should help you http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a0080134f18.shtml#topic2
Hoogen
Do rate if i have helped :)
Overall Rating: 5 (2 ratings)
