LAN
Feb 27th, 2007
In my LAN I have 20-25 Switches+Hubs and 2 L3 Switches.Occasionally I get 8-9 Request Time Out at any time in my LAN network. This can happen any time. how should I troubleshoot this. some times when I ping the Router Ethernet interface I get about 200 ms latency. pls help.
Arvind kumar Tue, 02/27/2007 - 22:47
how could I identify if there are broadcast storm in my network, how to identify and isolate that. is there any software available to help
Arvind kumar Fri, 03/02/2007 - 00:56
If the LAN interface on router is displaying high value of broadcast, how could I identify which particular IP is source for that broadcast
jvulto Fri, 03/02/2007 - 02:22
You can snif a LAN interface of the switch the Router is connected to.
Make sure you sniff in the same VLAN eq broadcastdomain here. If you realy experience a high volume of broadcast from just One host (not likely), it should be visible this way.
Arvind kumar Fri, 03/02/2007 - 03:27
pls explain how could i snif LAN interface of the switch the Router is connected to. Can I do it using some software. pls help
davidfc_A Thu, 03/08/2007 - 05:18
If your physical layer is ok, please verify the CPU of your switches and routers.
Routers with higher cpu utilization (above 95%) sometimes can drop or delay packets.
Tks
flashsplash Thu, 03/08/2007 - 07:23
also make sure that stp is running on all the switches and unplug the hub for a while.
