Command reference
Answered Question
Feb 27th, 2007
Hello, I have read something about the next commands of firewall service module 2.3(4) for Catalyst 6500:
- timeout xlate.
- timeout conn.
- timeout uauth.
... but it isn't very clear to me in the documentation. Could explain me somebody exactly so that it is each commando and who is the differentiate between timeout xlate and timeout conn?
Thank you and sorry for my bad English.
Regards.
Correct Answer by Jon Marshall about 9 years 7 months ago
timeout xlate is how long a Nat translation will remain on the firewall before it is deleted.
timeout conn sets the timeouts for tcp, udp, icmp, rpc, h323, h225, mgcp and sip. You can modify these timeouts if you need to. For example the standard timeout for a tcp connection is 1 hour but you might have to increase this for some Oracle applications.
timeout uauth is when users authenticate to the firewall for access to servers etc. This timeout defines how long that authentication will last before the user has to reauthenticate.
Jon
Overall Rating: 4.5 (2 ratings)
Correct Answer
Jon Marshall Tue, 02/27/2007 - 02:25
Jon
