3560 switch ssh
Feb 27th, 2007
If want to connect to 3560 switch using SSH must I have IP services ios on device?
thanks!
hoogen_82 Tue, 02/27/2007 - 03:13
Could you paste the current show version of your switch?
SSH support is available in most images, just look for a k9 in them.
Cheers
Hoogen
dragec Tue, 02/27/2007 - 03:27
well I do not have k9 in ios name. If I want to upgrade from -ipbase-mz to ipbasek9-mz, what part no from pricelist defines this upgrade? Or is it for free?
thanks!
hoogen_82 Tue, 02/27/2007 - 03:34
Could you post your show version, only then i would able to guide you to the right image!
Cheers
Hoogen
dragec Tue, 02/27/2007 - 03:49
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWAR
E (fc)
sESB032 uptime is 27 weeks, 3 days, 17 hours, 42 minutes
System restarted at 20:03:30 UTC Fri Aug 18 2006
System image file is "flash:c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.S
EB4.bin"
cisco WS-C3560G-48PS (PowerPC405) processor (revision D0) with 118784K/12280K by
tes of memory.
Processor board ID FOC1023Y39E
Last reset from power-on
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address :
Motherboard assembly number :
Power supply part number :
Motherboard serial number :
Power supply serial number :
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3560G-48PS-S
System serial number :
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number :
Top Assembly Part Number : 800-25836-03
Top Assembly Revision Number : A0
Version ID : V03
CLEI Code Number :
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560G-48PS 12.2(25)SEB4 C3560-IPBASE-M
Configuration register is 0xF
hoogen_82 Tue, 02/27/2007 - 03:55
This is the link from where you could download your image. It is a c3560-ipbasek9-tar.122-25.SEB4.tar
http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosresult.cgi?get_crypto=&data_from=&hardware_name=CAT3560&software_name=IP%20BASE%20WITH%20WEB%20BASED%20DEV%20MGR&release_name=12.2.25-SEB4&majorRel=12.2&state=:HW:SW:RL&type=Early%20Deployment
I checked up with my sales guy, they confirm that there is no extra charge.
Hoogen
Amit Singh Tue, 02/27/2007 - 05:26
Just to add to Hoogen's post you need a CCO login to download the image from the link posted above.
-amit singh
