Can't ssh router from a router ...
Feb 27th, 2007
Following is the configuration of vty lines on my router:
line vty 0 4
login local
transport input ssh
I am able to ssh my router with the help of putty (ssh utility) but when I try to ssh the same router from another router using command: ssh <ip address>, it asks the password but no login. When I enter my usual ssh password (which is in the local database of the router to which I ssh: username **** password ****) it does not accepts and ask again password until it kicks me out. Can anyone please help me to know why I can't ssh a router from another router? Thanks.
Overall Rating: 5 (1 ratings)
m.sir Tue, 02/27/2007 - 05:12
You can try -l options when you are trying log in using your user name
try following command when connecting from router
ssh -l
then you should enter only password
M.
Hope that helps rate if it does
sqambera Tue, 02/27/2007 - 21:28
Thanks a lot. It solved the problem. But still I am confused that why is it happening now, I mean before this I used to ssh directly using "ssh command and simply supply the password? Thanks again.
m.sir Tue, 02/27/2007 - 23:44
The client takes the current user and passes that to the server as the username to
login as.
To override this you must supply a username
with command
ssh -l
Its same like for UNIX systems.
M.
