Cisco loadbalance switch
Feb 27th, 2007
Hello All,
We are using Linux loadbalancers in our data center to manage failover, high availability between servers, now we are thinking to replace linux load balacing with cisco loadbalance switch, i need the recommendation of switch, while i wounder whether cisco loadbalance switch works same as linux loadbalancers?
thanks
Amit Singh Tue, 02/27/2007 - 05:52
What kinf of switches you are unsing in your Datacenter.If you are using Cat6500's then you can use Cisco CSM module on the chassis to do the server load-balancing on more than that.
http://www.cisco.com/en/US/products/ps6077/index.html
If you are not using 6500 you can go for Cisco 11000 series server load-balancers. You can get a fixed config model and a modular chassis in the series
http://www.cisco.com/en/US/products/hw/contnetw/ps792/index.html
HTH,
-amit singh
nayyares1 Tue, 02/27/2007 - 06:10
Thanks for reply, btw, is it possible to loadbalance traffic using 4900 series catalyst. As somebody told me that all layer 4-7 switches are capable of doing it, thanks
