Concentrator VNP3030 error
Feb 27th, 2007
I can't access to my concentrator by http and i receive the following errors on the logs:
"Semaphore error incfg_get"
"Semaphore error in cfg_access_hours_allowed"
does somebody know what this error means ?
regards
Ajit Singh Tue, 02/27/2007 - 16:32
There are couple of bugs related to the error message. The logs somewhat looks like following:
-atl-3060a 3483317 06/20/2006 19:52:27.820 SEV=3 CONFIG/42 RPT=1
Semaphore error in cfg_access_hours_allowed().
or
%CONFIG-4-42: RPT=2: Semaphore error in cfg_access_hours_allowed().
Sep 15 06:19:11 AHM-VPN-Secondary.amerhonda.com 14301585: 2004 Sep 15 06:19:11.620 PDT -7:00 %AUTH-4-5: RPT=2156: 32.101.149.161: Authentication rejected: Reason = Access hours restrictions in effect handle = 792, server = (none), user = ahm-pilot, domain =
workaround:
- Remove the SNMP server out of the device configuration (if any)
- The issue was seen in codes less than 4.1.7. Will suggest to upgrade to the Latest code available.
Please test and update.
Ajit Singh
