02-27-2007 07:08 AM - edited 03-11-2019 02:39 AM
hello,
I have two 515e in a failover pair. One has UR and the other FO licenses. The IOS version is 7.21.
They are failing over every minute or so. When I connected the console, it showed a lot of information like what you get in 'sh tech' and then it rebooted. Same thing is happening with the other device too. I have upgraded them from version 6.3 to 7.21 last week Thursday.
Can someone advise?
Regards.
Solved! Go to Solution.
02-27-2007 10:02 AM
There was a very common bug related to esmtp inspection. I would first recommend disabling esmtp inspection. Here is how you can do so-
policy-map global_policy
class inspection_default
no inspect esmtp
exit
exit
However, if this does not help, I would request you to provide the log you are getting on console. Basically, it is "traceback". You can also get the same from "show crash".
Vibhor.
02-27-2007 10:02 AM
no inspect esmtp
exit
exit
Vibhor.
03-01-2007 02:27 AM
Hi Vibhor,
Many many thanks for your instructions. They really solved my problem. However, I have upgraded the PIX to 7.22 now and it seems to be working fine now.
Shoaib.
