vpt set to transparent and need to change to client
Answered Question
I have a old c3500xl, running ios version -c3h2s-mz.120-5.WC16.bin
How can I change the vtp operation mode from transparent to client.
from the ios I don't see how to setup to client mode.
i.e.
SW2#conf t
Enter configuration commands, one per line. End with CNTL/Z.
SW2(config)#vtp ?
file Configure IFS filesystem file where VTP configuration is stored.
Never used a FILE???
Please help,
yanic
Correct Answer by b.petronio about 9 years 7 months ago
SWINFOR_1#vlan database
% Warning: It is recommended to configure VLAN from config mode,
as VLAN database mode is being deprecated. Please consult user
documentation for configuring VTP/VLAN in config mode.
SWINFOR_1(vlan)#vtp ?
client Set the device to client mode.
domain Set the name of the VTP administrative domain.
password Set the password for the VTP administrative domain.
pruning Set the administrative domain to permit pruning.
server Set the device to server mode.
transparent Set the device to transparent mode.
v2-mode Set the administrative domain to V2 mode.
SWINFOR_1(vlan)#vtp cli
SWINFOR_1(vlan)#vtp client
SWINFOR_1(vlan)#?
VLAN database editing buffer manipulation commands:
abort Exit mode without applying the changes
apply Apply current changes and bump revision number
exit Apply changes, bump revision number, and exit mode
no Negate a command or set its defaults
reset Abandon current changes and reread current database
show Show database information
vlan Add, delete, or modify values associated with a single VLAN
vtp Perform VTP administrative functions.
SWINFOR_1(vlan)#apply
SWINFOR_1(vlan)#exit
"Done"
Overall Rating: 5 (1 ratings)
Correct Answer
b.petronio Tue, 02/27/2007 - 08:11
SWINFOR_1(vlan)#?
"Done"
