Can be changed the IP and MASK for a IP/VC3500??
Answered Question
Feb 27th, 2007
we have a IP/VC3500 and we need change the default route, but we can?t because the new mask is diferent. This machine can a VxWorks S0. ?Can change this iP and MASK? or is neccesary change for console??
thanks
Correct Answer by drolemc about 9 years 7 months ago
In the Advanced section of the Settings tab, you can send text-based commands used for the enhanced control of the MCU.
Step 1 In the Administrator interface, on the sidebar, click MCU (if not already selected).
Step 2 Click the Settings tab.
Step 3 Click the Advanced button. select the route.
The following URLs should help you:
http://www.cisco.com/en/US/products/hw/video/ps1870/products_installation_and_configuration_guides_list.html
Overall Rating: 5 (1 ratings)
Correct Answer
drolemc Mon, 03/05/2007 - 10:55
