mac-address-table loses entries
Feb 27th, 2007
I have a 2801 router with a 4 port POE switch card. I have a PC plugged into one of the switch ports.
For some reason every 1 or 2 min I stop seeing the MAC in the mac-address-table (it is still in the arp cache though).
If I start pinging it again I lose the first 15-20 pings and then I can ping it again (the mac-address-table get populated again witgh the right info). After 1-2 minutes I lose it again...
any ideas ?
(I have increased the aging time with no luck)
thanks,C
guruprasadr Mon, 03/05/2007 - 01:30
HI,
Make the interface to Learn the MAC address of the PC vis Static Mode
Eg: "switch-port port-security mac-address static "
Not an right Syntax but this will help you.
Rate if Helps
Thanks & Regards,
Guru Prasad R
