BGP and VRF configuration issue
Feb 27th, 2007
We are trying to use BGP and VRF on our border gateway.
We have two ISP (ISP1 ISP2) and a BGP session with each of them.
On the border gateway we have two VRF: each of them is associated
to a different local AS (AS1 AS2).
The BGP process defined on the border is BGP AS2 and we defined
two BGP session: the first with the AS-ISP1 and the second
with AS-ISP2.
router bgp AS2
no synchronization
bgp log-neighbor-changes
network x.y.0.0 mask 255.255.224.0
aggregate-address x.y.0.0 255.255.224.0
neighbor 193.206.128.137 remote-as AS-ISP1
neighbor 193.206.128.137 local-as AS1
neighbor 193.206.128.137 version 4
neighbor 213.140.31.108 remote-as AS-ISP2
neighbor 213.140.31.108 ebgp-multihop 255
neighbor 213.140.31.108 version 4
The problem is that the ISP2 correctly receives our announced
network with AS-Path: AS2
whereas ISP1 receives our announced network
with the AS-Path: AS1, AS2: we would instead the
AS-Path to be AS1.
We cannot use the replace-as feature because it is not supported
in our IOS release 12.2(18)SXF6. Is there any other way to do it ?
Thank you,
Alessandro Asson
deilert Tue, 02/27/2007 - 09:16
Who is AS1? where are you picking up the AS from ?
can you paste in a sh ip bgp x.x.x.x
and a sh ip bgp nei 193.206.128.137 advertised
sh ip bgp nei 213.140.31.108 for that network
Harold Ritter Tue, 02/27/2007 - 13:27
Alessandro,
I do not see any other way to do this. The replace-as knob is available in 12.2(33)SRA though.
Hope this helps,
rebecca.richards Tue, 02/27/2007 - 19:59
hmm... If you want to be known to ISP1 as AS1, and ISP2 as AS2 (for whatever reason), wouldn't you be better off using BGP confederations?
cineca Wed, 02/28/2007 - 08:44
We have two separate ASes: AS1 to be known to ISP1 as AS1 and AS2 to be known to ISP2 as AS2. They represent two routing domain that have to keep separate. With the confederation
on the contrary I understand that I can announce the two (or more) local AS as one.
Alessandro Asson
cineca Wed, 02/28/2007 - 08:12
Ok, thank you.
The problem is that 12.2(33)SRA seems not
to support VRF ligth..
Best Regards,
Alessandro Asson
