Configuration for 871W multiple SSID's
Feb 27th, 2007
Can someone provide me with a sample config of more than three ssid's being configured on a 871W. I can get two ssid's to work but not more than that. Here is part of my config.
Thanks!
interface Dot11Radio0
encryption vlan 1 mode ciphers tkip
encryption vlan 20 mode ciphers tkip
ssid GuestWLAN
vlan 20
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii guestwireless
ssid Test
vlan 1
authentication open
wpa-psk ascii xxxxxx
channel 1
no cdp enable
no dot11 extension aironet
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.20
description Guest wireless LAN - routed WLAN
encapsulation dot1Q 20
ip address 192.168.202.1 255.255.255.0
ip nat inside
interface Vlan1
description Internal Network
ip nat inside
ip virtual-reassembly
bridge-group 1
interface BVI1
description Bridge to Internal Network
ip address 192.168.201.1 255.255.255.0
ip nat inside
bridge 1 route ip
Scott Fella Tue, 02/27/2007 - 11:36
Never mind... it worked after I reloaded the router. Figures... should of done that a long time ago.
