Late collisions and interface reset
Feb 27th, 2007
I'm getting a lot of late collisions on the WAN side of my router (Cisco 2801.) In the log I am also seeing errors every few minutes where that interface will come back up. I am having throughput issues with this router and I think this may be a duplex mismatch. Does this sound right?
wcraft.htawork Tue, 02/27/2007 - 09:23
rtr#sh int
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is 0019.2fa4.38f8 (bia 0019.2fa4.38f8)
Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$
Internet address is 10.10.10.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 4000 bits/sec, 3 packets/sec
5 minute output rate 2000 bits/sec, 2 packets/sec
15086034 packets input, 88230789 bytes
Received 4353489 broadcasts, 0 runts, 0 giants, 0 throttles
2 input errors, 0 CRC, 0 frame, 1 overrun, 0 ignored
0 watchdog
11475289 packets output, 3392575167 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
FastEthernet0/1 is up, line protocol is up
Hardware is Gt96k FE, address is 0019.2fa4.38f9 (bia 0019.2fa4.38f9)
Description: $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
Internet address is 66.101.199.34/30
Half-duplex, 100Mb/s, 100BaseTX/FX
Input queue: 0/75/39/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 9000 bits/sec, 14 packets/sec
5 minute output rate 3000 bits/sec, 3 packets/sec
29679920 packets input, 335398060 bytes
Received 18194333 broadcasts, 0 runts, 0 giants, 0 throttles
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
11108075 packets output, 3375348659 bytes, 0 underruns
27501 output errors, 22690 collisions, 26708 interface resets
0 babbles, 27613 late collision, 0 deferred
NVI0 is up, line protocol is up
Hardware is NVI
MTU 1514 bytes, BW 10000000 Kbit, DLY 0 usec,
Encapsulation UNKNOWN, loopback not set
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
rtr#
deilert Tue, 02/27/2007 - 09:25
that is correct Late Collisions are generally caused by a duplex mismatch
Amit Singh Tue, 02/27/2007 - 09:33
Your WAN FE interface is working as 100MB half duplex, that's why you are getting a lots of late collisions and output errors. Please check the duplex part on the other side and match it. It should be fine after the settings are same at both the sides.
-amit singh
wcraft.htawork Tue, 02/27/2007 - 13:48
Yep - was able to force it to Full Duplex/100Mbps and the late collisions have stopped. Thanks for the feedback.
