IPS Event Viewer
Feb 27th, 2007
I use IPS Event Viewer to run some reports for an IPS 4215. This week when I ran a report and click on the graph there are blocks of time that show no events being logged at that time. But when I look for events during this same time period on the IDM or CLI they show up.
Is there a reson for this?
Thanks for any info.
rhermes Wed, 02/28/2007 - 10:41
Check the severity of the events missing on your Event Viewer report. You may have only selected to download Med and High severity events to the Event Viewer. (I think this is the default for VMS)
ymzhang Wed, 02/28/2007 - 11:21
The alarms might have already been archived in archival table (by default config, it archives everyday). So if you try to drill down from the Realtime Graph, you won't see the alarms. I think you can try to use "Statistics Graph" which can be reached by right-click the View name.
Hope this helps,
-Chris
