PIX 515 OS update from 6.3(2) to 6.5(5)
Feb 27th, 2007
What is the best possible procedure the PIX is placed at remote location.
I only have ssh connection with it.Basically i want to copy the running configuration and the current IOS so i cant delete it and copy the new one .Plz tell me how to upgrade it as well as the procedure and the command to copy IOSA from flash to TFTP and from TFTP to Flash
Overall Rating: 5 (2 ratings)
vitripat Tue, 02/27/2007 - 14:13
- You can save the configuration of PIX to TFTP server using following command:
--> write net
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/tz.htm#wp1027782
- We cannot copy the PIX image to flash. If you need to save the current OS image for backup, you can download it from cisco.com.
- To upgrade the firewall, following command is used:
--> copy tftp flash
http://www.cisco.com/warp/customer/110/upgrade.shtml#upgrade511
Hope this helps.
Vibhor.
