CME4.0(2) - VTA - Outgoing calls blocked
Answered Question
Hi pros,
I've installed a CME and I have VTA on the phones, the video works great, but when I have video on, I am not able to make any calls out to the PSTN.
Once I exit the VTA application on the PC, I am able to call.
Please HELP!
Joe
Correct Answer by astinus about 9 years 7 months ago
Joe,
I had the exact same problem. See the link below:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080569b65.shtml
It refers to CCM, but the fix is applicable to the voice port. The short version of it is, go to your voice-gateway, go to voice-port config for your PSTN trunk and enter bearer-cap speech. This should get you rolling.
Remember to rate helpful posts!
Jim
Overall Rating: 5 (1 ratings)
Correct Answer
astinus Wed, 02/28/2007 - 06:39
Joe,
Jim
