Dual ACE servers dial-up VPN on a 3600 router
Feb 27th, 2007
We currently have VPN users connecting through a 3640 router and want to add a 2nd RSA ACE server.
The 3640 is using IOS 12.3
Does any one know if this will support a 2nd RSA server?
Richard Burts Tue, 02/27/2007 - 16:52
Mike
Some more detail about what you are doing would be helpful and enable us to give you better answers. Would I be correct in assuming that if you are terminating VPN sessions on the 3640 that you are using TACACS or Radius to authenticate with the RSA server? If so then I believe that the answer is affirmative - the 3640 does support a second TACACS or Radius server.
Rick
daviddtran Sun, 03/04/2007 - 18:02
you can use native Radius Server that comes with
RSA Server to autheticate VPN users. You can
add a second RSA Server replica (provided you
have the primary RSA server in place) and it
will replicate the user database from the
primary RSA to the secondary RSA. From the
Cisco 3640, you will have two Radius entries,
one with the IP address of the primary RSA
server and another entry with the IP address
of the secondary RSA server.
I am using RSA server to terminate vpn users
on my cisco 2621 routers with this scenario
but my configuration is a bit more complicated
than yours. I have ACS server that will proxy
off the connection to the RSA Server (I
have RSA agent installed on the ACS). But the
first approach is much easier.
Good luck.
David
CCIE Security
Checkpoint CCSE NGx
