cisco switch 2960
Feb 27th, 2007
whether 2960 is a l2 layer or l3 layer
Samir Aliyev Tue, 04/16/2013 - 14:11
Layer 2 switch.  Although it may be L3 functions (ACL,QoS,IPSG, etc.) ,   it's NOT LAYER 3 switch.
Because it does not have IP Routing Capability.
Bilal Nawaz Tue, 04/16/2013 - 14:38
Cisco introduced Layer 3 switching on the 2960S, 2960G, 2960, and 2975 series switches when running the LAN BASE IOS with version 12.2(55)SE.
But there’s a small catch…it does NOT support RIP, OSPF, EIGRP, BGP, or routed interfaces. It ONLY supports 16 static routes with SVIs.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/relea...
Hope this helps
