Insert a access-list rule
Feb 27th, 2007
If I need to add a new rule in the middle of an exist ACL, do I have to re-write the whole ACL? Can I just add this rule to the right place based on access-list sequence number?
vitripat Tue, 02/27/2007 - 14:01
If you are running 6.3 code, you can add access-list at any position you want. This can be done using "line no." in the access-list command. For eg. I can use following command to add access-list at porion 10 in the existing ACL of 20 lines:
access-list 101 line 10 permit ip any any
Hope this helps.
Vibhor.
