NAC Framework with 802.1x authentication
Feb 27th, 2007
I am having trouble getting support and information on NAC framework. According to the cisco web NAC framework is in Phase 2 and is useable. According to Cisco representitives it is not supported yet. I have ACS 4.1, CTA 2.0, Symantec 10.1.4, and CSA 4.5. I can get NAC to work Layer 2, 802.1x to authenticate, but I cannot get both to work at the same time. Also, I have found no support for Symantec being checked even after I loaded the posture plugin, adf, etc. Is it time to give up on NAC framework? Thanks.
jphelan3415 Mon, 03/05/2007 - 13:38
I appreciate the link, but I have been through it.
Here is a better question--has anyone been able to check the following using only ACS 4.0/4.1, Cisco dot1x capable switch, CTA 2.0, and Symantec AV:
Dot1x authentication
Symantec AV product levels (version 10)
Windows OS service packs/hot fixes
CTA levels
CSA levels
lmilher_2 Mon, 03/19/2007 - 06:10
My friend, i have a customer with whis configuration and worki fine.
symantec need antivirus version 10 (8 or 9 no !!!!), the symantec posture plug installed in the clients.
work fine wiht w2k and xp
cta 2.x work fine. 1.x only work with L3 ip, no 802.1x.
csa i don?t have experience.
take care, it is hard to configure, if you need something more ask me to.
Leo.
