RDP 3389 Forwarding
Feb 27th, 2007
Hey all, Im new on here and a newbe with cisco. I have a customer I have set up a Cisco 870 which is working. I am trying to set up RDP to my server on there network.
My config is as follows.
NAT Config
Static
Direction from inside to outside
Translate from: IP address: server (local)
translate to:
Type: Interface
interface: dialer0{ATM0.1}
Redirect Port TCP 3389
Firewall Rule:
Permit
Source: any
Destination: any
tcp source: any
tcp destination: 3389
I have tried changing the destination address to my servers but it still doesn't connect when i use remote desktop from home to my server.
I would appreciate any help!
:P
ggilbert Tue, 02/27/2007 - 15:23
Would it be possible if you could see if there is any ACL's on the outside interface. If so, please make sure you have the IP and the port allowed.
Also, if you could please see if the statement is configured as given below that would be great.
ip nat inside source static 10.10.10.1 3389 interface Dialer0 3389
Where 10.10.10.1 would be the internal IP address of the server.
Let me know.
Gilbert
Rate it, if this helps!!
morrisj3_80 Wed, 02/28/2007 - 10:06
Thanks Gilbert for the responce.
I have since reset the router, and only set up the internet with no firewall.
The IP Address of cisco internal: 10.4.124.1
IP Address of Server to RDP to: 10.4.124.32
All i have set up now is NAT
Static
Direction : inside out
Tanslate from 10.4.124.32
no netmast
translate to: outside Dialer0
Type Interface
redirect to 3389
I get the error the client computer could not connect to the remote computer.
Can you set up the Cisco router using only 1 ip address??
Thanks for all your help
ggilbert Wed, 02/28/2007 - 10:24
Can you please cut and paste the command that you have on the Cisco router for the NAT section.
You should be able to map the internal address and tcp port to the interface address.
sh ip nat trans
The above command will give you the output of static translation that you had configured for.
Gilbert
morrisj3_80 Tue, 03/06/2007 - 03:10
Hi Gilbert,
Thanks for all your help I have no resolved this problem. I set up an FTP server and that worked fine through the firewall it was a problem with my laptop and remote desktop rather than the firewall.
John
