VPN3000 Load Balancing - Configuration Synchronization
Answered Question
I have found information on setting up concentrators for load balancing and have that figured out. I cannot find out any information about how the member devices keep their configurations in sync. Is this automatic or does it required updating all members manually when changes are made?
Correct Answer by ggilbert about 9 years 7 months ago
Dennis,
Automatic sync of the config on the concentrators is not possible. You would need to sync the configs manually.
Cheers
Gilbert
Rate this post, if it helps
Overall Rating: 4 (1 ratings)
Correct Answer
ggilbert Tue, 02/27/2007 - 15:29
Dennis,
Cheers
Gilbert
