switch hierarchical design
Feb 27th, 2007
If switch hierarchical design as the attachment.
what is problem will be occurred?
Thanks!
Samuel
Overall Rating: 4 (1 ratings)
samuel0901 Thu, 03/01/2007 - 04:50
i think switch should be within 3 layers, i.e. core, distribution, access layer. if it is more than 3 layers. it should has problem, but i forgot what's wrong. Does anyone can talk me what it is?
Thanks!
Samuel
jdevoll Thu, 03/01/2007 - 13:20
The purpose of the hierarchical model is to accommodate performance requirements, and to set clear functional boundaries for services in you LAN. Cisco's model is the 3 tier model, therefore it is the most widely used. This is not a hard rule, but it certainly is time tested. The only hard and fast rule is that STP diameter should not exceed 7 switches, and you can even circumvent that (highly ill advised).
samuel0901 Fri, 03/02/2007 - 07:36
hi jdevoll,
right, it is stp diameter problem.
how to check whether some wrong if diameter exeeed 7?
Thanks!
Samuel
carl_townshend Mon, 03/05/2007 - 09:04
on this also, i would run the spanning tree root at the distribution layer and use layer 3 between that and the core.
cheers
