vpn tunnel failed after changing ISP - no outgoing traffic
Feb 27th, 2007
Hi forum,
Sorry, I am trying hard on this problem. initially my ASA firewall can ping the destination ASA firewall public IP. But after changing the ISP, by adding another router in front, I can't ping the remote ASA IP address, I am not sure this is the cause of my VPN tunnel to fail. but Internet access has no problem.
I really appreciate if anyone can help.
Thank you,
paul
Following are some errors captured:
Message #92 : Feb 06 00:48:54 [IKEv1]Message #93 : : IP = 2.2.2.2, Removing peer from peer table failed, no match!
Message #94 : Feb 06 00:48:54 [IKEv1]Message #95 : : IP = 2.2.2.2, Error: Unable to remove PeerTblEntry
Message #96 : Feb 06 11:39:40 [IKEv1]Message #97 : : Group = 2.2.2.2, IP = 2.2.2.2, Removing peer from peer table failed, no match!
Message #98 : Feb 06 11:39:40 [IKEv1]Message #99 : : Group = 2.2.2.2, IP = 2.2.2.2, Error: Unable to remove PeerTblEntry
Message #100 :
IKE_TMR DPD_TIMER (0x01383360) popped @ time = 1229314
<--- More --->
Message #101 :
IKE_TMR DPD_TIMER (0x01383360) popped @ time = 1229315
Message #102 :
Message #125 :
IKE_TMR REAPER_TIMER (0x01388260) popped @ time = 1229336
Message #126 :
Message #135 :
IKE_TMR DPD_TIMER (0x01383360) popped @ time = 1229345
Message #136 :
IKE_TMR BACKUP_L2L (0x013833d0) popped @ time = 1229346
Message #137 :
IKE_TMR REAPER_TIMER (0x01388260) popped @ time = 1229346
Message #138 :
IKE_TMR DPD_TIMER (0x01383360) popped @ time = 1229346
Message #139 : Feb 07 19:21:26 [IKEv1]Message #140 : : IP = 2.2.2.2, Removing peer from peer table failed, no match!
Message #141 : Feb 07 19:21:26 [IKEv1]Message #142 : : IP = 2.2.2.2, Error: Unable to remove PeerTblEntry
Message #143 : Feb 07 19:21:27 [IKEv1]Message #144 : : IP = 2.2.2.2, Header invalid, missing SA payload! (next payload = 4)
Message #145 : Feb 07 19:21:34 [IKEv1]Message #146 : : IP = 2.2.2.2, Header invalid, missing SA payload! (next payload = 4)
Message #147 : Feb 07 19:21:42 [IKEv1]Message #148 : : IP = 2.2.2.2, Header invalid, missing SA payload! (next payload = 4)
Message #149 : Feb 07 19:21:50 [IKEv1]Message #150 : : IP = 2.2.2.2, Header invalid, missing SA payload! (next payload = 4)
Message #151 : Feb 09 05:28:00 [IKEv1]Message #152 : : IP = 2.2.2.2, Removing peer from peer table failed, no match!
Message #153 : Feb 09 05:28:00 [IKEv1]Message #154 : : IP = 2.2.2.2, Error: Unable to remove PeerTblEntry
Message #155 : Feb 09 16:13:36 [IKEv1]Message #156 : : IP = 2.2.2.2, Removing peer from peer table failed, no match!
Message #157 : Feb 09 16:13:36 [IKEv1]Message #158 : : IP = 2.2.2.2, Error: Unable to remove PeerTblEntry
pixfirewall# ping 2.2.2.2
Sending 5, 100-byte ICMP Echos to 2.2.2.2, timeout is 2 seconds:
ICMP echo reply from 2.2.2.2 to 1.1.1.1 ID=4388 seq=58029 len=72
Denied ICMP type = 0, code = 0 from 2.2.2.2on interface 1
?ICMP echo reply from 2.2.2.2 to 1.1.1.1 ID=4388 seq=58029 len=72
Kamal Malhotra Wed, 02/28/2007 - 14:09
Did you get the peer IP changed on the remote device?
If not, then please get that done.
HTH,
Please rate if it helps.
Kamal
paulnigel Wed, 02/28/2007 - 18:01
Hi Kamal,
Yes, the peer IP for the remote device was changed.
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 52069, #pkts decrypt: 52069, #pkts verify: 52069
I cannot see pkts encrypt, etc.
Removing peer from peer table failed, no match! ====> what is the meaning of this message?
Thank you very much,
paul
