EAP-PEAP AUTHENTICATION
Feb 28th, 2007
hi
am using CISCO ACS SE to authenticate my users who connect to my wireless network from the microsoft AD..am using EAP-PEAP.
the authentication works fine the problem is that after authenticating and associating my Client connects for about 5 minutes and reconnects again and it does this continously in intervals of 5 minutes..whare could i have gone wrong.
ebreniz Tue, 03/06/2007 - 06:43
I don't think there is any issue with the authentication server unless you have set the client session interval to as low as 5 mins. Could you check what is the client session interval configured? Does it happen to all clients?
akobwaycct Tue, 03/06/2007 - 06:50
yes it happens to all clients...where exactly do i check the client session interval in the ACS or WLC.
Vivek Santuka Thu, 03/08/2007 - 03:00
On the ACS->Group Setup Select Radius IETF Attribute 27 - Session Timeout - and set it to a high value.
Vivek
Trending Topics - Security & Network
