Import 4096-bit root CA fails
Feb 28th, 2007
Hello
I tried to install our new root CA to our Cisco 3030 VPN Concentrator. But as the certificate has a length of 4096-bit, the import fails reporting: "Error installing trusted certificate: Unsupported key size."
Thank you for any help.
Daniel Bertolo
Kamal Malhotra Wed, 02/28/2007 - 13:51
Hi Daniel,
Alex seems to have answered your queries. Cisco VPN 3000 series concentrators do not support 4096 bit key for the certificates. It only supports upto 2048. 4096 is only supported on the ASAs.
HTH,
Please rate if it helps,
Kamal
