Router to Firewall VPN Connection
Feb 28th, 2007
I have a 3825 router that terminates client vpn connections and a remote PIX that terminates client vpn connections and tunnels to 2 other PIXs. I want to build a site-site tunnel. I have configured the 3825 as follows:
crypto isakmp policy 3
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key ****x address**** no-xauth
crypto isakmp nat keepalive 20
crypto isakmp client configuration group admins
key ***
dns 10.65.1.200
wins 10.65.1.200
domain ***
pool ippool-admin
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
crypto map clientmap 20 ipsec-isakmp
set peer ****
match address 199
interface Serial0/1/0
ip access-group 101 in
ip nat outside
access-list 199 permit ip 10.65.2.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 199 permit ip 10.65.1.0 0.0.0.255 192.168.0.0 0.0.0.255
The PIX config:
access-list 100 permit ip 192.168.0.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 100 permit ip 192.168.0.0 255.255.255.0 192.168.4.0 255.255.255.0
access-list 100 permit ip 192.168.0.0 255.255.255.0 10.62.1.0 255.255.255.0
access-list 100 permit ip 192.168.0.0 255.255.255.0 10.65.1.0 255.255.255.0
access-list 100 permit ip 192.168.0.0 255.255.255.0 10.65.2.0 255.255.255.0
access-list 160 permit ip 192.168.0.0 255.255.255.0 10.65.1.0 255.255.255.0
access-list 160 permit ip 192.168.0.0 255.255.255.0 10.65.2.0 255.255.255.0
nat (inside) 0 access-list 100
sysopt connection permit-ipsec
crypto ipsec transform-set HQset esp-3des esp-md5-hmac
crypto dynamic-map vpnclientmap 10 set transform-set HQset
crypto map HQmap 3 ipsec-isakmp
crypto map HQmap 3 match address 130
crypto map HQmap 3 set peer ***
crypto map HQmap 3 set transform-set HQset
crypto map HQmap 4 ipsec-isakmp
crypto map HQmap 4 match address 140
crypto map HQmap 4 set peer ***
crypto map HQmap 4 set transform-set HQset
crypto map HQmap 6 ipsec-isakmp
crypto map HQmap 6 match address 160
crypto map HQmap 6 set peer ***
crypto map HQmap 6 set transform-set HQset
crypto map HQmap 20 ipsec-isakmp dynamic vpnclientmap
crypto map HQmap interface outside
isakmp enable outside
isakmp key ******** address *** netmask 255.255.255.255 no-xauth no-config-mode
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
All vpn clients work correctly and the tunnels to the two branch offices (using PIX-PIX) but cannot route traffic between the site with the router to the central PIX. ANy help would be appreciated to guide me in the right direction.
thanks
buzzyng99 Wed, 02/28/2007 - 01:22
well, on the router, ACL 199 is local lan - remote lan
on the PIX, ACL 160 is the opposite of that since it is local lan - remote lan
buzzyng99 Wed, 02/28/2007 - 02:36
from the router lan side (10.65.1.x)
when I traceroute from a client it goes to the router (.1) and then dies.
here is the output from the router:
#sh crypto map
Crypto Map "clientmap" 10 ipsec-isakmp
Dynamic map template tag: dynmap
Crypto Map "clientmap" 20 ipsec-isakmp
Peer = ****
Extended IP access list 199
Current peer: ***
Security association lifetime: 4608000 kilobytes/3600 seconds
PFS (Y/N): N
Transform sets={
myset,
Interfaces using crypto map clientmap:
Serial0/1/0
#sh crypto session
Crypto session current status
Interface: Serial0/1/0
Session status: DOWN
Peer: *** port 500
IPSEC FLOW: permit ip 10.65.1.0/255.255.255.0 192.168.0.0/255.255.255.0
Active SAs: 0, origin: crypto map
IPSEC FLOW: permit ip 10.65.2.0/255.255.255.0 192.168.0.0/255.255.255.0
It appears that it never brings up the tunnel for traffic destined to the remote LAN 192.168.0.x
