CISCO Works
Feb 28th, 2007
when trying to poll the start up configuring using LMS version 2.6 it gives a partiual suucess message. Where the error is showing as
CM0208: user not authorized to perform the opertaion on device.
but i have provided the telnet password and enable password as the credentials. (wich are correct) but still its providing me with the same error message. Please advice.
Overall Rating: 4.5 (2 ratings)
David Stanford Wed, 02/28/2007 - 07:16
Can you check the following:
Common Services->Server->Security->Multi-Server Trust Management->System Identity Setup
Is the System Identity user configured?
Is there a file named "comUser.dat" in ?
Is LMS integrated with ACS?
mmssandhu Sun, 03/04/2007 - 22:17
thanks....the error was coming because i did not provide the credentials of telnet password and enable password on my core switch device....and all my edge switch is connected to the core switch.
But still i have some problem with one of the switches again ...when i try to fetch the configuration..it gives me partial success. The error that shows me is that it was not able to archive....please advice...thnaks for the eariler one..
