best monitoring tools
Feb 28th, 2007
Hi all, can anyone tell me the best, most useful and easiet to use monitoring tools, ie for troubleshooting my network ?
rebecca.richards Wed, 02/28/2007 - 20:53
Carl,
Probably the best tool around (an industry standard tool perhaps?) is MRTG. Another extremely useful tool, written by the same guy is SmokePing.
MRTG will graph your network utilisation. Smokeping will graph your network latency. Using those two tools alone will tell you which networks are having problems.
For a Flight Deck utility, have a look at Nagios.
For router/switch configuration backups, look at Rancid.
All of them are Open Source :)
Cheers,
- bec
sebastianvandijk Thu, 03/01/2007 - 01:02
If you are considering SNMP try JFFNMS !!!
It conaints smokeping, rrdtool, mrtg, config backups, syslog server, SLA's and it is for free :) !!
You can graph almost anything you can imagine.
Check http://www.jffnms.org
