One time passwords for managemet on WLC.
Feb 28th, 2007
I?m trying to use a "one time" password i my radius solution then working with management through the GUI and https.
( One time password works for the CLI)
I have enabled the "Credentials Caching" but still it does not work as I expect.
The webserver on WLC still require that I logg in for every request or "click" I do in the GUI.
Do anyone have any information about this. If it works? And if, what more is required?
josh.yost Mon, 03/10/2008 - 12:41
I am experiencing this same issue. A debug shows that the GUI seems to be re-sending the credentials for each frame it loads, and then for each click. WHen I log in to the CLI - I have no problems whatsoever and have the appropriate access. Is anyone use SecurID or other OTP for Management of WLCs successfully?
MATS KARLSSON Tue, 03/11/2008 - 05:30
Hi !
I have had a ServiceRequest open at TAC on this problem and it is now solved. In controller release 5.0.148.0 this works fine and I can now use our SafeWord solution with OTP when we login to the controller.
/Mats
Trending Topics - Security & Network
