WLC 4402 lost APS
Feb 28th, 2007
hi
i executd the cmd reset system on my WLC 4402 and after that i lost all the APs that were joined to the WLC,how do i get the APs back.
Try setting Master Controller Mode on your WLC (it can only be enabled on one controller at a time).
Also, you can bounce the APs (if they are on PoE switches by doing a SHUTDOWN and the then a NO SHUTDOWN on the ports feeding the access points.
In certain situations, this has gotten the APs to connect.
You may also want to check your IP address settings because if you had not saved your settings prior to the reset, they may be lost/reverted to default settings.
- John
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
