Content / cache engine question
Answered Question
Feb 28th, 2007
Does anyone know the difference between "bypass static" and "rule action no-cache pattern-list"
It seems to me both tell the content engine not to cache the specified URL.
Correct Answer by Syed Iftekhar Ahmed about 9 years 7 months ago
bypass static permits traffic from specified sources to bypass the Content
Engine. The types of traffic sources are as follows:
Specific web client to a specific web server
Specific web client to any web server
Any web client to a specific web server
Examples
This example forces HTTP traffic from a specified client to a specified server to bypass the Content Engine.
ContentEngine(config)# bypass static 10.1.17.1 172.16.7.52
This example forces all HTTP traffic destined to a specified server to bypass the Content
Engine.
ContentEngine(config)# bypass static any-client 172.16.7.52
This example forces all HTTP traffic from a specified client to any web server to bypass
the Content Engine.
ContentEngine(config)# bypass static 10.1.17.1 any-server
intstructs cache engine to NOT cache ANYTHING from a particular web URL.
This example forces CE to not cache anything from www.donotcache.com
rule enable
rule action no-cache pattern-list 18 protocol all
rule pattern-list 18 domain www.donotcache.com
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Wed, 02/28/2007 - 12:30
Examples
Engine.
the Content Engine.
rule enable
huangedmc Thu, 03/01/2007 - 14:26
Does it mean these two would have the same result? (no cache to particular site)
rule pattern-list 18 dst-ip 172.16.7.52
I was trying to find the difference between these two.
thanks.
Syed Iftekhar Ahmed Thu, 03/01/2007 - 14:35
Perspective is different
"bypass static any-client 172.16.7.52"
will force HTTP traffic destined to 172.16.7.52 to bypass the Content Engine.
Where as
"rule action no-cache pattern-list 18 protocol all
rule pattern-list 18 dst-ip 172.16.7.52"
will instruct Content engine to not cache any thing from 172.16.7.52.
What are you trying to achieve?
Syed Iftekhar Ahmed
huangedmc Sat, 03/03/2007 - 21:25
Both result in the site not being cached though right?
So far we've identified severl sites that don't work well w/ caching, and would like the content engine NOT to cache anything from those sites.
I assume both methods would work in my case?
What exactly did you mean traffic would bypass the content engine in your first example?
Traffic would go straight from client to webserver?
Syed Iftekhar Ahmed Mon, 03/05/2007 - 00:16
With static bypass
The "origin server" will observe traffic coming directly from "client IP" not from CE's IP.
Syed Iftekhar Ahmed
