How to test RDBMS Synchronization on one ACS server
I'm trying to test importing ACS users from the "accountActions" table in a database using RDBMS Synch on a single disconnected test server using ACS 3.3 Win 2000 Svr. When I synch manually, it requires a Synch Partner which I do not have. How can I test this using a single server?
thanks!
Vivek Santuka Thu, 03/01/2007 - 06:00
You will need to put the ACS on the network and restart ACS. A default Self AAA Server entry will be created which can be used as a DBSync partner.
Vivek
