Mulitple IPs on Pix
Answered Question
Feb 28th, 2007
We are going to be migrating from one set of IPs to another, and I need to get some items clarified/verified.
1st- Can you have multiple IP addresses assigned to a single interface.
2nd- We will need to move some mappings, will having multiple mappings to the same internal address work? With the internal tables in use to keep track of each connection, I would assume so, but I would like some clarifications.
Todd
Correct Answer by suschoud about 9 years 7 months ago
1. no.
2. you cannot map multiple public ip addresses on outside to the same internal ip address.
Overall Rating: 5 (1 ratings)
Correct Answer
suschoud Fri, 03/02/2007 - 07:33
1. no.
