WS-X4448-GB-SFP
Feb 28th, 2007
Are the ports on these line cards configurable for the speed? I need to attach network printers that only have 10/100 TX cards in them and I'm trying to figure out what's the best way to handle this? Configure the port (assuming that's an option)and put a cheaper media converter on OR put a $300+ Gb media converter on. Thanks in advance!
Carla Decker
Amit Singh Wed, 02/28/2007 - 11:34
Carls,
Generally the ports on these modules are not configurable and it depends on the SFP transceiver modules that you are using. However using GLC-T 1000base copper SFP modules you can configure the speed to 10,100,100 or auto. Please have a look at the link below for more info.
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml#config1
HTH,Please rate if it does.
-amit singh
