wireless implementation
Feb 28th, 2007
i will need to implement only 5 wireless access points for my company meeting rooms.i have thought to implement Cisco Aironet 1240AG to operate
as an autonomus AP.considering the fact that my catalyst 2950-24 concentrated in one catalyst 6506 does not support POE i will use the power supply
will i encounter any kind of problem if the WLAN controller will not be used
rob.huffman Wed, 02/28/2007 - 10:04
Hi Mehmet,
For 5 AP's you don't need the WLC at all. To run these in Autonomous mode will work just fine! For power options you could also use power injectors if there is no A/C outlet near the AP mounting location;
Cisco Aironet Power Injector (AIR-PWRINJ3) Cisco Aironet power injectors use the power supply that is available with Cisco Aironet 1240AG Series access points.
From this good AP1240 Guide
http://www.cisco.com/en/US/products/ps6521/products_qanda_item0900aecd8031c8dc.shtml
Also, don't forget antennas;
Antennas for both 2.4-GHz and 5-GHz radios are available and must be ordered separately. High-gain omnidirectional, narrow-beam directional, diversity, and nondiversity antennas are available for both operating bands.
For more information on antenna options, visit:
http://www.cisco.com/en/US/products/hw/wireless/ps469/index.html
Hope this helps!
Rob
m-daja Sun, 03/04/2007 - 06:17
thanks for your reply ROB.
i think to implement Cisco 1130AG series for indoor use in autonomus mode
rob.huffman Sun, 03/04/2007 - 07:47
Hi Mehmet,
The 1130 will be an excellent choice as well. We use them in our environment quite successfully :) Make sure to order the IOS version for your rollout;
AIR-AP1131AG-x-K9 Cisco IOS Software
Where x =
A=FCC
C=China
E=ETSI
I=Israel
J=TELEC (Japan)
K=Korea
N=North America (Excluding FCC)
P=Japan2
S=Singapore
T=Taiwan
From this good doc;
http://www.cisco.com/en/US/products/ps6087/products_data_sheet0900aecd801b901c.html
Hope this helps! And best of luck,
Rob
