CCM 5.1.1 new install
Answered Question
Feb 28th, 2007
For CCM 5.1.1, how can I local login (or remote desktop, or VNC) to the server to access C drive do the MoH source file upload etc.
Also, for internal voice lab 192.x.x.x (no connection to production network 10.x.x.x), what basics configurations that are needed to set up a CCM-Pub, 2900 switch, and two 7960 IP phones to call from one phone to another.
Correct Answer by thisisshanky about 9 years 6 months ago
To apply patches you can put the update file in a ftp or sftp server (the file is usually a signed binary image) and go to Platform Administration web interface - > Software upgrades and specify the file name, ip address of ftp/sftp server, username and password and the image should be pulled down from the server. You can also burn the image into a dvd media and place it locally on the server. You can select the method of upgrade as DVD/CD, instead of ftp server in this case.
Sankar
PS: please remember to rate posts!
Correct Answer by rob.huffman about 9 years 7 months ago
Hi Denming,
Here is some info related to cli access etc;
Starting a CLI Session
You can access the Cisco IPT Platform CLI remotely or locally:
From a web client workstation, such as the workstation that you use for Cisco IPT Platform Administration, you can use SSH to connect securely to the Cisco IPT Platform.
You can access the Cisco IPT Platform CLI directly by using the monitor and keyboard that you used during installation or by using a terminal server that is connected to the serial port. Use this method if a problem exists with the IP address.
Before You Begin
Ensure you have the following information that gets defined during installation:
A primary IP address and hostname
An administrator ID
A password
You will need this information to log in to the Cisco IPT Platform.
Perform the following steps to start a CLI session:
Step 1 Do one of the following actions depending on your method of access:
From a remote system, use SSH to connect securely to the Cisco IPT Platform. In your SSH client, enter
ssh [email protected]
where adminname specifies the Administrator ID and hostname specifies the hostname that was defined during installation.
For example, ssh [email protected]-1.
From a direct connection, you receive this prompt automatically:
ipt-1 login:
where ipt-1 represents the host name of the system.
Enter the administrator ID that was defined during installation.
In either case, the system prompts you for a password.
Step 2 Enter the password that was defined at installation.
The CLI prompt displays. The prompt represents the Administrator ID; for example:
admin:
You can now use any CLI command.
From this 5.1 doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008079bbfa.html
Cisco Unified CallManager Operating System Administration Guide, Release 5.1(1)
Software Upgrades
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008079bc1c.html
Hope this helps!
Rob
Correct Answer by dconstantino about 9 years 7 months ago
LX is the OS and CCM.5.1 is an appliance and is locked down. To download updates and patches it is done through CLI and SFTP. no remote desktop SecureCRT and or VPN and browse in. I would recommend reading up on CCM 5.1 SRND and the Install guide. There is not enough time or space on this thread to walk you through Installing.
Overall Rating: 5 (4 ratings)
Correct Answer
dconstantino Wed, 02/28/2007 - 12:28
dchen0999 Wed, 02/28/2007 - 12:36
Thanks dconstantino. I will check them out.
The CCM 5.1.1 pub is installed and running. Just need to do some configurations and get the phone to call each other and to test some features, like MOH, etc.
(This is internal test lab, no production network connection is needed now)
thisisshanky Wed, 02/28/2007 - 19:26
To upload a moh file, there is a menu item under Media resources called MOH file management
Sankar
dchen0999 Thu, 03/01/2007 - 12:41
This works.
> How about CCM 5.1.1 OS and patch update?
It seems CLI is not working. Any Cisco doc pointing to how to use CCM 5.1.1 CLI?
Thanks Sankar and Everyone for the help.
Correct Answer
rob.huffman Thu, 03/01/2007 - 14:12
Hi Denming,
Before You Begin
An administrator ID
A password
ipt-1 login:
admin:
From this 5.1 doc;
Software Upgrades
Hope this helps!
Rob
dchen0999 Thu, 03/01/2007 - 14:54
1. The CLI prompt displays. The prompt represents the Administrator ID; for xample:
admin:
I am here.
2. From this 5.1 doc;
This works.
3. Software Upgrades
This will work.
4. What if CCM 5.1.1 OS or Patch Update?
Thanks Rob for your great help and
Have a wonderful day to All.
dchen0999 Thu, 03/01/2007 - 15:05
dconstantino answers this already in this thread sometime ago: Through CLI or SFTP.
Thanks.
Correct Answer
thisisshanky Thu, 03/01/2007 - 21:57
Sankar
