7920 auth failed -though verified ssid & encypt. correct
Feb 28th, 2007
we have two 7920's and seen that we could not get them to authenticate to AP though both ssid and the encryptions on both the 7920 & AP were correct.
both phones could not authenticate and all settings were correct.
it wasn't until we reset the phones to factory defaults and re-keyed all settings then we could auth to AP.
any suggests as to why such occured ??
strange....
migilles Wed, 02/28/2007 - 11:32
Sounds like a config issue.
Was it ever working? Did you upgrade/downgrade phone firmware?
Which authentication/encryption is used?
jherder78 Wed, 02/28/2007 - 12:29
we thought the same, but it was working fine. for the time that we used them and there was no upgrade, using latest firmware.
The thing I failed to say was that we had left the phone's go dead, and needed to re-charge them before usage. <-after recharge was when we saw them unable to authenticate or authenticate failed. we could only use them after resetting them to factory defaults and re-keying the configs.
authentication wep 128 bit,w/ with un-broadcasted ssid
