VPN access inside to outside on a 2821
Feb 28th, 2007
I am not sure how to allow for using a laptop inside to connect to the outside world with a VPN client. Are there certain ports I need to allow, and where. Please see the attached config. Thanks
Kamal Malhotra Wed, 02/28/2007 - 13:34
In the configuration, nothing seems wrong except the access-list from_internet is not bound with the interface. If it is actually like that then its fine but if it is bound with the outside interface then you need to make sure that you allow the UDP 500 and UDP 4500 from outside to inside.
HTH,
Please rate if it helps,
Kamal
starlog01 Thu, 03/01/2007 - 15:24
Kamal,
thanks for the reply, can you share with me how to bind the access list, then I will try it.
Tom
